Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
#17
OK, was working and hooked up fine. Then I downloaded the SDK and ARC new edition. When I hooked up the board to juice, it said I needed to upgrade firmware. Once finished it said I needed to reboot the EZB. After reboot, It would not connect to bluetooth. I checked the firmware and it said OK. I checked the ports and they said ok. The only thing that concerned me is that it is one Port3 and Port 5. It said Outgoing Port3 and Incomming Port5. I thought that you said the second port was for further enhancements. If this is so, then incomming and outgoing should be on the same port#3 and port5 should be a blank spare port with nothing on it. Am I correct? And HOW IN THE WORLD WILL I CHANGE IT???
D.J. I am feeding you information as fast as I can get it. hope it helps.
Good Luck! We are all counting on you! (LeslieNeilsonAIRPLANE).
Ireland
#18
Thanks DJ
it works perfectly now had same problem seemed to connect main led solid on but red (bluetooth) led began to flash, then got error that it could not connect.
To resolve issue I REMOVED my bluetooth device on pc,and set it up again entering pairing code. and it now connects without any problems. Thanks again Pat
Netherlands
#20
@ BRAVIA
Yes!, that did the trick for e aswell! I deleted EZ-B from the bluetooth device list then unplugged it and plugged it back in, reconnected it with EZ-B Com port and bingo!
Thanks! I'm happy!:D
#21
OK, I have installed/uninstalled both bluetooth and EZB many times. At first, I was on port 3 with port5, next I was on port 7 with 8. I still don't understand WHY the incomming and outgoing are on sepirate ports.
I guess I have to leave it alone for a while I am spinning in circles now.
Mel
#22
The Download has been put on hold. Please let us know when downloading can be resumed.
#23
OK, I am convinced that no matter what I do, it is NOT going to work. :-(
My system is Windows7 Five Core 16G Ram and 2 T Hard drive and ONE EZBoard that does not work.
Mel
Netherlands
#24
@ MovieMaker
Have you tried deleting the registered ports for EZ-B with blueTooth before uninstalling?
I have windows 7 too, I first rightclicked my bluetooth icon in windows tray, there i manually took out the registered ports for the EZ-B connection and then unplugged it. I plugged it back in and then only had to reactivate the EZ-B connection in windows control panel > hardware and devices, and it automaticly reconnected. That was all I did and it worked.
I noticed that at first that allthough i had my port 3, i did not have my port 4. I again rightclicked my bluetooth icon in tray and there i anually added the com 4 port to the EZ-B connection. I hope this may be of some help to you.
Kristian.
