Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
Resolved Resolved by Steve1DH!
V4 Two Way Serial Communication - Where Do I Connect To Read?
Hi all,
I'm trying to get serial feedback from a device. Does anyone know where on the V4 I should attach to read back serial information from device? I know I send a serial command to through one of V4's digital signal pins but where do I read it back from?
I thought it would be read from the same digital pin I sent the command. However @Toymaker made a comment in another thread that it may have to be read through one of the i2c ports.
Any insight is welcomed. :)
#17
Here's a huge secret, DJ's method above is how I manage to look like I know what I'm doing 99% of the time!:D
#18
Rich you're too modest... I would say more like 99.9%;)
#19
@ Dave - Thank You for the credit.
#20
:P @DJ, your a scream!; "calmly following these steps". "Calmly" is my middle name. ;)
Your right though. I could have probably found the answer to this question if I had just slowed down and re-read the spec sheet. I do get in a hurry at times. It usually results in a flash and smoke. eek
Also this is not for displays. I'm trying to set up a two way serial connection between EZB V4 and a Kangaroo / Sabertooth. I need the Roo to tell me where it is after I send a serial command to move to a set position.
#21
Lol you indeed are one of the most patient people I've ever met. I write for the masses, knowing that future readers will stumble across my posts. Never think I'm directing anything at any specific someone. It's always generic.
Much like how I explain where the learn button is. Of course you all know. But someone new may not know... So I be specific for the future:)
#22
Dave, I referred to I2C port as I am still using a V3 so my PIC does the conversion from I2C to bi-directional comms to the serial port of the Kangaroo, hope this helps.
#23
@Tony, each time you post it always a huge help. Thanks, the confusion was my fault not yours. When I thought it through I came to that conclusion.
#24
Ok... I can't find any example using uart method, neither in local examples nor in the cloud... is it me or they all disappeared?
Some basic quesitons :
I'm trying to TX buffer values (between 0 and 640) from an arduino (running a code to read motors' encoders) to EZB UART0. I hooked arduino's tx to EZB's rx and arduino's rx to tx (although I only need to receive data from arduino, but in the doubt... not sure if they both need to be connected).
I tried these codes so far, without success :
UARTInit( 1, 0, 9600 )
$available = UARTAvailable( 1, 0 )
print($available)
UARTRead(0, 0,$available)
UARTReadBinary(0, 0, $available, $variab)
print($variab)
sleep(200)
halt()
here is what I get :
Start
1: UARTInit( 1, 0, 9600 )
3: $available = UARTAvailable( 1, 0 )
5: print($available)
> 0
7: UARTRead(0, 0,$available)
9: UARTReadBinary(0, 0, $available, $variab)
11: print($variab)
> Error on line 11: Variable is an array: $variab
Done (00:00:00.1605282)
FYI if you type what the Script Help says about UartReadBinary() you get an error message :
UARTReadBinary(0, 0, UARTAvailable(0, 1), $variable)
here is what it returns :
16: UARTReadBinary(1, 0, UARTAvailable(0, 1), $variable)
> Error on line 16: Missing ) in Expression
Done (00:00:00.4367821)
that's why I used a variable for the UartAvailable() function, above.
I'm desperately trying to get data returned. It works in the terminal EZB, I receive the counts from the encoders connected to the arduino. So, here is my real question (and since I couldn't find any example using UART keyword in the examples despite what was said earlier in this thread) :
How do I get to read what comes from this arduino the same way they are read and displayed in the serial terminal?
Thanks in advance
