Omron HVC-P2 icon Omron HVC-P2 — Omron HVC-P/HVC-P2 ARC plugin: Python-based camera integration for body, hand and face detection, gaze, age/gender, expressions and face recognition. Try it →
Resolved Resolved by Steve1DH!
V4 Two Way Serial Communication - Where Do I Connect To Read?
Hi all,
I'm trying to get serial feedback from a device. Does anyone know where on the V4 I should attach to read back serial information from device? I know I send a serial command to through one of V4's digital signal pins but where do I read it back from?
I thought it would be read from the same digital pin I sent the command. However @Toymaker made a comment in another thread that it may have to be read through one of the i2c ports.
Any insight is welcomed. :)
#25
Ok, one step at a time:) I see the variable's value in the variable watch... so now need to figure out how to script with these values as a variable condition...
#27
Thank you very much Dj! And enjoy your evening! I hope she's worth it!:D
#28
Thanks! I'll write something if you're still spinning wheels later this evening
#29
ok, if anyone else is arround, here is what I'm now facing : don't seem to be able to get ASCII strings...
here is the error message I get using this code plagiarized from ARC examples :
the code first :
UARTInit( 1, 0, 9600 )
:loop
$available = UARTAvailable( 1, 0 )
print("Bytes in buffer: " + $available)
$read = UARTRead(1, 0,$available)
print("Received: " + $read)
sleep(1000)
goto(loop)
And now the error message I get :
Start
1: UARTInit( 1, 0, 9600 )
3: :loop
5: $available = UARTAvailable( 1, 0 )
7: print("Bytes in buffer: " + $available)
> Bytes in buffer: 0
9: $read = UARTRead(1, 0,$available)
11: print("Received: " + $read)
> Received:
13: sleep(1000)
15: goto(loop)
3: :loop
> Bytes in buffer: 16
> Error on line 11: Missing String Quotes or Invalid Expression at index 15: "A
Done (00:00:01.1545633)
It's supposed to read these values :
"A=" then a number between 0 and 640 "B=" then a number between 0 and 640.
It seems that it can't read ASCII string values... maybe it's the "=" ?
** update : it is not... even after changing the code in arduino to only return numbers... I get this :
Start
3: :loop
> Bytes in buffer: 0
> Received:
13: sleep(1000)
15: goto(loop)
3: :loop
> Bytes in buffer: 6
Done (00:00:01.5197188)
#30
the question is missing some info. Is the arduino sending an unsigned 16 bit int? Signed 16 bit int? Or a string of characters?
Because it can't be an 8 bit unsigned int cause that only goes to 255.
What is the arduino sending?
#32
it was initially sending a string of charaters AND a int (it seems int is by default signed in arduino).
Arduino int stores a 16-bit (2-byte) value by default.
I took out the string of characters but I still get this error message :
15: goto(loop) 3: :loop 5: $x = UartAvailable(1, 0) 7: print("Bytes in buffer: " + $x)
Bytes in buffer: 7 9: $y = UARTRead(1, 0, $x) 11: print("Received: " + $y) Error on line 11: Missing String Quotes or Invalid Expression at index 15: " Done (00:00:02.4873538)
