are these to get for 3 volt also ?
— Edited
5 Participants
Diagnostic Report
— Collects and sends ARC diagnostic reports to Synthiam to help troubleshoot EZ-B and robot connection issues
Nope...ez robot only makes a 5V version... What do you need 3V for?
If you need a 3V version buy an adjustable one from... Josh... Adjustable voltage regulator
RR
from joch are 4.7 volt.i need 3 volts.i got led blinker with swiths. i thought to build in the dome.
@nomad18.08 the white digital pins (signal) are 3.3v just connect black to any ground and positive to a white digital pin and add a PWM control that's how I control small LEDs
BBORASTERO
no need for regulator then.
thanks
bborastero
that works great.
Wooo! It's twinkly at nomad's
dj
it will look good on six and galapagos bot.
