PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
#25
@Steve G if by 10Mh you mean 10mA then yes!:D
STEVE G/JEREMIE
i though six and galapagos can use some sparkeling,hehe
thanks
#27
@Jeremie I didn't see the digital pin's current limitations in the ezb4 spec sheet so I assumed it was 20mA (as you mentioned) like other micros.... Thanks for clarification....
i made some leds to test.these have all separt ports to be able random lid up. is this possible to when i use all leds on one port?
#29
@nomad.
Not directly, no. They would flash at the same time. Although that's not to say you couldn't make a circuit (if you know how to) and run them off one port so they flash independently. I wouldn't know how to make such a circuit so I can't help much, but maybe somebody else does. Or see if you can find an LED flashing circuit online from somewhere.
steve g
ok steve thanks
here the 8 eyes off six.i made them a little slower then as chown in the video. now it needs detection mode rapid flaching.
