Indonesia
Thingiverse Google+ YouTube
Why My Camera Always Disable
I recently received EZ-B , a gift from EZ-Robot Community thanks for it.
when i try for first time, I have a problem with my ez-robot camera whenever I press start to view camera always disable camera message appears, but for control the servo is fine and working except the camera. If Using my laptop cam is working. i try to check the wire and Pin connection all is fine (im use Multy tester for check that) , the blue led camera is blinking when Ez-B is turn on but when i press start to view cam, camera disable message appears. i no have ide for this proble, can somebody help me. Thankyou
chouldn ezbv4 ip same as camera?
Indonesia
yes is same, and i try all cam option on video device but still camera disabled
take a look as this pic. also what batterie do you use?
Indonesia
yes is same ip with EZb, and i try another cam option is still same, but if using webcam is working. 6x AA rechargeable battery 700mah, and i try use lipobattery 7,4v 1300mah
yes i gess its the batterie to weak.
Indonesia
but that work to servo movement multy servos, so i must using battery in 2000mah and up? lest i try it, thankyou nomad:)
If the led is flashing... Maybe the cable is damaged.
It would help to see the error. Press the copy button and paste it here.
