Augmented Reality icon Augmented Reality — Overlay PNG/JPG images in real-time onto detected objects, faces, colors or glyphs using ARC Camera tracking; attach, preview, detach. Try it →
Indonesia
Thingiverse Google+ YouTube
Why My Camera Always Disable
I recently received EZ-B , a gift from EZ-Robot Community thanks for it.
when i try for first time, I have a problem with my ez-robot camera whenever I press start to view camera always disable camera message appears, but for control the servo is fine and working except the camera. If Using my laptop cam is working. i try to check the wire and Pin connection all is fine (im use Multy tester for check that) , the blue led camera is blinking when Ez-B is turn on but when i press start to view cam, camera disable message appears. i no have ide for this proble, can somebody help me. Thankyou
Indonesia
@DJ Sures, oke Dj
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2/1/2015 9:37 AM - Camera Disabled 2/1/2015 9:37 AM - Camera Initialized: EZB://192.168.1.1 @ 320x240 2/1/2015 9:38 AM - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2/1/2015 9:38 AM - Camera Disabled
Indonesia
@DJ Sures, sorry DJ this is complete paste
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - TCP Server stopped 2/1/2015 9:44 AM - Attempting connection on 192.168.1.1:23 2/1/2015 9:44 AM - Connected to 192.168.1.1:23 2/1/2015 9:44 AM - EZ-B reports EZ-B v4 OS 2/1/2015 9:44 AM - Welcome to EZ-B v4 Beta! 2/1/2015 9:44 AM - EZ-B v4 ID: 73-51-0-0-47-255-56-60-56-38-38-37 2/1/2015 9:44 AM - Connected 2/1/2015 9:44 AM - Setting battery monitor voltage: 6.6 2/1/2015 9:44 AM - Setting battery protection: True 2/1/2015 9:44 AM - Setting i2c rate: 100000 2/1/2015 9:44 AM - Camera Initialized: EZB://192.168.1.1 @ 320x240 2/1/2015 9:45 AM - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2/1/2015 9:45 AM - Camera Disabled 2/1/2015 9:45 AM - Camera Initialized: EZB://192.168.1.1 @ 320x240 2/1/2015 9:45 AM - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2/1/2015 9:45 AM - Camera Disabled 2/1/2015 9:45 AM - Camera Initialized: EZB://192.168.1.1 @ 320x240 2/1/2015 9:45 AM - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2/1/2015 9:45 AM - Camera Disabled 2/1/2015 9:45 AM - Camera Initialized: EZB://192.168.1.1 @ 320x240 2/1/2015 9:45 AM - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 2/1/2015 9:45 AM - Camera Disabled
Indonesia
@nomad, I already use the lipo battery 1300mah 7, 4v as used for six, jd or Roli, and i also attempt to use the recharger Alakaline battery 2400Mah, but stil camera disabled . confused
the blue LED flashes when on turn on. as long as the camera is turned on felt warm can be in touch
can you open the cam to see inside?
Indonesia
yes the dev.kit cam coming without case. i has a check all conection pin and wire using multy tester and all is connect.
then i gess we wait to dj what he says.
Indonesia
#15
well I am just waiting for a reply from a dj he would know where the faults with the data that I sent. thankyou Nomad
