Wowwee Rovio icon Wowwee Rovio — Movement panel integrating WowWee Rovio with Synthiam ARC for remote drive, live camera, audio and docking control. Under development. Try it →
#17
havent got that board,but looking to get it,one i got is little different but has same output i havent tested it yet on EZB waiting on RJ45 protoboard board to come in to have both WIFI and wired network on EZB,i think both should work ok only thing i check that the virtual port shows up on EZB as com 5 and on my computer may be your board it bad or ? have you tested it with the software from elechouse
#18
also might check your firewall to see if you have that port added,if not can add one easy
#19
just had a quick (and I mean really quick) search on this and everything I come across showed it being set to server not client
1~virtual port shows up on EZB as com 5 and on my computer ( yes )
2~have you tested it with the software from elechouse ( yes )
3~ it being set to server not client ( ok i will check that )
thanks this is driving me nuts and can't put computer on rc robot.If i get this to work (make me happy) and @Dj will have a new way to sell his product that we all love.
#21
couple of other things to check i see it needs 5 volts for that board check the voltage on EZB
other item check your EZB again with bluetooth to see if your EZB is ok another item last resort switch the pins tx and rx there are other tests to try,i forgot the name right now but you need to tie tx and rx on wifi board and use term program second is you wifi on your computer setup and wifi board on computer shows it listed at networking i am very good at it
#22
@pittom did you get it working? I'm looking at using the same board for my build as bluetooth isn't good enough for the range I need
#23
so so, i got it to connect but ez gives me some data (some readings on voltage monitoring ) but that's all, my scanning servo won't even move. I think data is supper slow,rechecked ez with bluetooth and works.@richmr2 was wright i had it in clint not server mode.
Still trying
#24
SO how its in the setting,you should get near 54mbps
