#25
I couldn't login to the free single virtual port GUI so found one that does the same thing but costs $99 a port. I still can't access EZ-B, here's what I get:
Found a fix, When using independent battery supplies to power the WiFi board and the EZ-B, the batteries need to share a common ground.
#26   — Edited
Quote:
Ok several days of trying and here is where i am at. My new WIFI came in(USB-TTL module was bad on old one) all drivers loader and with help of this POST I did this setup
SETUP LINK get to setup auto mode and here is what i get
0.0.0.0 stays connected to router
192.168.1.1 cycles every 10 seconds
192.168.1.139 does not connect
i can ping fine when connected to router.
a free virtual serial port thanks @robotmaker
virtual serial port
but won't connect with any settings i put in server address and yes every thing is all set to 9600.
also set port forward 192.168.1.139 to port 8090
Don't know where to go from here,wish i was smarter *stress*
 :DThanks for the manual, I managed to repeat your path and with the server assignment and virtual serial port everything worked as Rich advised
