Cognitive Sentiment icon Cognitive Sentiment — Detects positive sentiment percentage of input text using cognitive ML; returns $SentimentPercentage, shows face, graph, and status for analysis. Try it →
D.COHRAN thanks means dj assembly in mine builder is not correct. ok gonna put the wires on now.
#99
Mine also says D4 for upper left arm.... did you sync your ez bit library (not sure if that has anything to do with it)?
wires are connected now.
i can check rr
RR it stays desame.
d.cohran
are degrees in your pic also good?
#102
those were for one frame of a movement.
I would download the one from the cloud now that you have yours configured like that.
#103
You want the servo legs to be perfect straight when set to 90. Use the servo Fine Tune to adjust the legs to be straight at 90. And use the servo Fine Tune to adjust the feet to be straight flat at 90
Use the + and - buttons on the leg servos to make them perfectly straight at 90. The offset will increase/decrease to help you align the servos.
You can save the fine tune settings for next time.
