just got mail from ez ,my order is chipped.
— Edited
Kinect Xbox 360 Depth Mapping
— Converts Xbox 360 Kinect depth frames into NMS obstacle scans for ARC path planning, SLAM, and obstacle avoidance.
thats why it possible not connect to wifi.
if i see jd's eye tonight am very happy.
Nomad, Did you get him charged up and on the network?
he still charging.but the wires are all connected.
d.cohran thanks very much for your support.i will needed.
d.cohran
do i need to choose same ports ?or can i choose?
If you are using the sample from eZ-robot, you will want to use the ports they used. If not, when you expect a leg to move, he is going to smack himself in the face
if you want to use different ports, you can, as long as a digital stays a digital and so on. It just will mean that you will need to modify the ARC app to use the new port numbers. This would be in any Auto Position controls, scripts and anything else that uses an input or output other than sound and video.
ok i will change them and use original.
Use the EZ-Robot Instructions to wire the robot. It tells you where to connect the wire in the top left for each EZ-Bit
