just got mail from ez ,my order is chipped.
— Edited
Wheel Encoder Counter
— Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS.
the charger get real hot?is this normal?
is the battery hot?
no the charger
I saw that you got 2 chargers in your video. I would try using the other charger to see if you have the same issue with that one. The charger and batteries that I have like the ones you got do not get hot. Hot charging lipo battery can be very dangerous. Please try the other charger.
The charger will get quite warm and sometimes very hot. Make sure your robot is turned off while charging
i change the charger and this one is cold
It might be cold because the battery is now charged from the other charger
Nomad, I would just wait until the battery is all used up again and try it with this charger.
Also, make sure not to run your batteries down any lower than about 6.6 volts. Doing so could damage the battery. (Technically you can go down to 6 volts but why push it?)
