hi
is it possible to ad a check box here so i dont see this message ? i try them upgrade but dont work .no matter what i do .
thank you
Soundboard (EZB)
— Play WAV/MP3 via EZ-B v4, manage tracks, add timed scripts for synced robot actions, control via ControlCommand(), volume and clipping indicators.
hi
thank you
Hi @Nomad,
I would recommend clicking update on each of those green buttons. The box will then disappear. Having the latest updated skill is highly beneficial. The updated versions have feature updates, bug fixes, and most of the time the documentation matches the most recent version of the skill.
hey jeremie
when i click the green buttons ,an instalation starts and at the end it says failed. all of the green buttons says desame failed . i use the latest version off ARC . here's a little video .
thank you
https://www.youtube.com/shorts/3g7oKULE5oY
Thanks for the video @Nomad, Could you copy/paste all the error text and post it in this thread?
Please make sure there are no other copies of ARC running when you push the update button.
deleted post . due to misunderstanding .
Thanks, Nomad! Sorry, I meant copy/paste all the text from one of the error boxes. DJ needs to see the text above the error message that you screenshot.
ah this you mean .silly me .
Local File: C:\Users\Gebruiker\AppData\Local\Temp\ARC\03c529f5-10ec-42a6-b86d-a26806703510.ezplugin Downloading https://admin.synthiam.com/WS/GetPluginV2.aspx?guid=03c529f5-10ec-42a6-b86d-a26806703510 Installing C:\Users\Gebruiker\AppData\Local\Temp\ARC\03c529f5-10ec-42a6-b86d-a26806703510.ezplugin Archive Filesize: 44 232 Bytes Installing to C:\ProgramData\ARC\Plugins\03c529f5-10ec-42a6-b86d-a26806703510
Extracting File: Overlays/HUD/0visor.png (773 Bytes to 1 030 Bytes) File exists, deleting System.UnauthorizedAccessException: Access to the path 'C:\ProgramData\ARC\Plugins\03c529f5-10ec-42a6-b86d-a26806703510\Overlays\HUD\0visor.png' is denied. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.File.InternalDelete(String path, Boolean checkHost) at System.IO.File.Delete(String path) at ARC_Plugin_Manager.Form1.Xh1woNmVngPRjXkpcSOD.bPMQrXm9Bv0RZS01pwEx(Object ) at ARC_Plugin_Manager.Form1.Xh1woNmVngPRjXkpcSOD.MoveNext()
Perfect, thanks @Nomad!
One thing you can try is to go to C:\ProgramData\ARC\Plugins\ and delete the plugins that are there and try and re-update them.
Maybe start with one as a test.
ah ok jeremie . thank for your input .
