hi
is it possible to ad a check box here so i dont see this message ? i try them upgrade but dont work .no matter what i do .
thank you
Omron HVC-P2
— Omron HVC-P/HVC-P2 ARC plugin: Python-based camera integration for body, hand and face detection, gaze, age/gender, expressions and face recognition.
hi
thank you
Nomad do you have more than one copy of ARC running at a time? This would happen if the files are locked by two or more copies of ARC running at the same time.
what Jeremie suggested by deleting the files in that folder is the best solution to your problem
hi dj
no i use only one ARC . strange i cant find this " C:\ProgramData\ARC\Plugins\
one question if i may .were is the best folder to store the plugings ?i dont see a folder in the picture ?
thank youThat’s because you’re in my documents. It’s c:\program data\arc\plugins
so the plugins should not be installed in documents? i cant find the c:\program data\arc\plugins i can see c: but not c:\
so the plungins should no be installed in documents ? i can see c: but not c:\
dj,jeremie
problem solved . i didn paste the last \ after the word plugin .
thank you bolt .
Awesome Nomad! That is good to hear! You're a great robot artist.
