hi
i have set a iotiny on connection 3 . when i want to make some visuals ARC freezes in seconds . what can be the cause ?
Live Stream Broadcast
— Broadcast live audio and video from ARC camera to the web via HLS; cross-browser streaming. Requires router configuration for external access.
hi
It sounds like you're experiencing an issue where ARC freezes when you try to make some visuals with your IoTiny on connection 3. Here are a few steps to help diagnose and potentially resolve the issue:
1. Check Connection Stability
Ensure that your IoTiny is properly connected and that the Wi-Fi connection is stable. You can use the Connection Diagnostic skill to help diagnose any connection issues.
2. Review Debug Information
The Debug skill can provide valuable information about what might be causing the freeze.
3. Check for Software Updates
Ensure that you are using the latest version of ARC and that all your robot skills are up to date.
4. Inspect the Placeholder Skill
Since the Placeholder skill is in beta, it might have some issues that could cause ARC to freeze.
5. Check Resource Utilization
High CPU or memory usage can cause ARC to freeze.
6. Test with a Simple Project
Create a simple ARC project with just the IoTiny connection and a basic visual element to see if the issue persists.
7. Review Power Supply
Ensure that the IoTiny is receiving a stable power supply.
8. Submit a Diagnostic Report
If the issue persists, you can submit a diagnostic report to Synthiam for further assistance.
By following these steps, you should be able to identify and resolve the issue causing ARC to freeze. If you need further assistance, please provide more details about your setup and any error messages you encounter.
@athena
is it possible that this iotiny is not supported for rgb?
The EZ-B IoTiny does support RGB LEDs, but there are some considerations to keep in mind regarding power and control. Here are a few points to consider:
1. Power Requirements
RGB LEDs can draw significant current, especially if you are using multiple LEDs or high-brightness LEDs. The IoTiny's power output might not be sufficient for high-power RGB LEDs, and you may need an external power source.
2. Control Method
The IoTiny can control RGB LEDs using PWM (Pulse Width Modulation) on its digital ports. However, you need to ensure that the control method you are using is compatible with the IoTiny.
3. Wiring and Connections
Ensure that the RGB LEDs are correctly wired to the IoTiny. The typical wiring for an RGB LED involves connecting the common anode or cathode to the power supply and the individual RGB pins to the digital ports on the IoTiny.
4. Software Configuration
Make sure that your ARC project is correctly configured to control the RGB LEDs. You can use the PWM control in ARC to adjust the brightness and color of the LEDs.
5. External Drivers
For high-power RGB LEDs, you might need an external driver or controller that can handle the current requirements. The IoTiny can send control signals to the external driver, which then powers the LEDs.
6. Testing with Simple Setup
To verify if the IoTiny can control your RGB LEDs, start with a simple setup:
Example Setup
Connect the RGB LED:
Configure ARC:
Test Control:
Troubleshooting
If you continue to experience issues, please provide more details about your RGB LED setup, including the type of LEDs you are using and how they are connected to the IoTiny. This will help in providing more specific guidance.
@athena
i tested whit a new project and ezbv .same problem . i use 6.5 volts .
@athena
i have 6.5 volts for avery ezbv and iotiny . do i see a lower volt in ARC . can this be the problem ?
Using 6.5 volts for your EZ-B v4 and IoTiny should generally be within the acceptable range, but there are a few considerations to keep in mind:
1. Voltage Monitoring
Both the EZ-B v4 and IoTiny have built-in voltage monitoring features. If the voltage drops below a certain threshold, it can cause instability or unexpected behavior. You can monitor the voltage in ARC to ensure it is stable and within the acceptable range.
2. Voltage Drop
If you are seeing a lower voltage in ARC than what you are supplying, it could indicate a voltage drop due to resistance in the wires or connectors. This can be caused by:
3. Power Supply Stability
Ensure that your power supply is stable and can provide sufficient current for all connected devices. An unstable power supply can cause voltage fluctuations, leading to issues.
4. Battery Monitor Settings
The EZ-B v4 and IoTiny have battery monitor settings that can be configured in ARC. If the battery monitor is set to a higher threshold, it might trigger warnings or shutdowns even if the voltage is within an acceptable range.
Steps to Diagnose and Resolve the Issue
1. Monitor Voltage in ARC
2. Check Connections
3. Test with a Different Power Supply
4. Adjust Battery Monitor Settings
https://192.168.1.1in your web browser.5. Simplify the Setup
Example of Monitoring Voltage in ARC
Add ADC Control:
Projecttab in ARC.Add Control.ADCfrom the list of controls.Configure ADC Control:
ADC0).Troubleshooting Tips
By following these steps, you should be able to diagnose and resolve any issues related to voltage that might be causing ARC to freeze. If the problem persists, please provide more details about your setup and any specific error messages or behaviors you observe.
@athena
i use a 40amps regulator new . all power wires are 12 gauge whit all new connectors . so no batteries are used . the warning low batterie is disabled . a steddy 5.98 volt from the big regulator and 6.50 steddy from small regulator .
two iotiny has 5.64 volt one ezbv has 5.70volt seconf ezbv has 5.64 volt .
https://www.youtube.com/shorts/hpmy8Dyg1T0
Thank you for providing detailed information about your setup and the video link. Based on your description, it seems like you have a robust power supply setup with a 40-amp regulator and 12-gauge wires. However, the voltage readings you provided (5.64V and 5.70V) are slightly below the 6.5V you mentioned earlier. This slight drop might not be significant, but it's worth investigating further.
Potential Causes and Solutions
1. Voltage Drop
Even though you have a powerful regulator and thick wires, there might still be a slight voltage drop due to connectors or the load on the system. Ensure all connectors are secure and free from corrosion.
2. Power Supply Stability
Ensure that your power supply is stable and not fluctuating under load. You can use an oscilloscope to check for any voltage spikes or drops.
3. Firmware and Software Updates
Ensure that your EZ-B v4 and IoTiny are running the latest firmware. Also, make sure you have the latest version of ARC installed.
4. Overheating
Check if any components are overheating. Overheating can cause instability and unexpected behavior. Ensure proper ventilation and cooling for your components.
5. Peripheral Load
Disconnect all peripherals and test the EZ-B v4 and IoTiny with just the power supply connected. Gradually add peripherals back to the setup, monitoring the voltage and stability in ARC.
6. Network Issues
Since the EZ-B v4 and IoTiny connect over Wi-Fi, ensure that your network is stable and has a strong signal. Network issues can sometimes cause ARC to freeze.
Add ADC Control:
By following these steps, you should be able to diagnose and resolve any issues related to voltage that might be causing ARC to freeze. If the problem persists, please provide more details about your setup and any error messages or behaviors you observe.
