hi
i have set a iotiny on connection 3 . when i want to make some visuals ARC freezes in seconds . what can be the cause ?
RGB 8X8 Animator
— Create, edit and play animated frames on an RGB 8x8 LED matrix via I2C with looping, adjustable pauses and scriptable EZ-Script canvas control.
hi
@athena
the adc line on number 3 is totally missing . what does that mean ?
https://www.youtube.com/shorts/BVC30xLenhw
Thank you for sharing the video link. If the ADC line on number 3 is missing, it could indicate a few potential issues. Let's go through some possible causes and solutions:
Potential Causes and Solutions
1. ADC Port Configuration
2. Hardware Connection
3. Firmware and Software Updates
4. Power Supply Stability
5. Interference and Noise
Steps to Diagnose and Resolve the Issue
1. Reconfigure ADC Port in ARC
2. Inspect Hardware Connections
3. Update Firmware and Software
4. Check Power Supply Stability
5. Reduce Interference and Noise
Example of Monitoring Voltage in ARC
By following these steps, you should be able to diagnose and resolve the issue with the missing ADC line. If the problem persists, please provide more details about your setup and any error messages or behaviors you observe.
@athena
some aditional info . i use two old ezbv4 . the one connected to number 2 is the one that keeps disconnecting , and after that the ezbv4 will not connect untill i reboot . it also changes its IP adres avery time . @athena what do you think needs to be done ?
Thank you for providing additional information. It seems like the EZ-B v4 connected to number 2 is experiencing connectivity issues, including frequent disconnections and changing IP addresses. Here are some steps to diagnose and resolve the issue:
1. Network Configuration
2. Firmware and Software Updates
3. Power Supply Stability
4. Network Interference
5. Hardware Issues
1. Configure Static IP Address
https://192.168.1.1.2. Update Firmware and Software
https://192.168.1.1.3. Check Power Supply Stability
4. Reduce Network Interference
5. Inspect Hardware and Test with Another EZ-B v4
Example of Configuring Static IP Address
https://192.168.1.1.By following these steps, you should be able to diagnose and resolve the connectivity issues with your EZ-B v4. If the problem persists, please provide more details about your setup and any error messages or behaviors you observe.
@athena
solved . it was a slow internet .
I'm glad to hear that the issue has been resolved! Slow internet can indeed cause connectivity problems, including frequent disconnections and changing IP addresses. If you have any more questions or need further assistance with your robot project, feel free to ask. Happy building and programming with ARC!
I'm glad you found a solution. You mentioned in a different post that you were going to get a new provider or upgrade your service plan. Is this what fixed your issue?
In the past I've assigned static IP addresses to EZBs in my router and that worked pretty well. However after upgrading my home network and making sure I had a strong and stable signal for the EZB's ended the need for the static IP.
Also, I've known a couple people who had 2 EZB's sitting too close to each other and being that close interfered with their network connection. However that was many years ago and before the EZB V4 came out. Perhaps that issue was solved with the new board or there were other things happening with their connection (slow, weak)? In the past I've operated two EZB within 3 inches of each other and had no issues but I have a strong home network and have the latest EZB V4 released. You mentioned that upir big EZB's are old. Do they have boards prior to the V4 release? Have you ever updated their firmware?
hi dave
i bouth some more internet . its 25 GB more for 5 euro x2 . i also have the Engenius acces point .
