HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
@Dj Or? Sound Servo(Ezb Playback)
I've been testing Rich's led tutorial https://synthiam.com/Community/Tutorials/135/1
I've been able to get it to work on, sound movement, sound servo(PC Mic), sounds servo(PC Speaker) but not able to get it to work with sound servo(EZB Playback). I have also noticed when hitting the? On the sound servo(EZB Playback) goes to the webpage talking about the sound servo(PC Mic). ?
Also when I use the sound servo(EZB Playback) and play something [sayezb(" test test test", 3) i hear this on the ezb speaker but the level on the sound servo(ezb playback) shows 0 never changes.
Well maybe I'm not understanding but I thought the sound servo(ezb playback) is used for the sound coming out of the speaker of the EZB controller to control a servo or in this case the LEDs.
Thanks
I also noticed in the Learn section under ARC manual, audio, it only lists sound server(EZB)
So maybe I missed that part by DJ and professors E. blush confused
@merne Do you have the Sound servo v4 control referencing the correct board? By default it is set to board 0. In your sayezb example above however you are using ezb4 board 3....
@Richard R,
[qoute] Do you have the Sound servo v4 control referencing the correct board? [/quote]
Yes I do.
That's strange as it works for me... Maybe try using it on board 0....
Ok, I just tried it on both V4 & V41/2 board 3 trying it on board0
@Richard R.
That's very interesting. I just tried on board 0 and it does work! It only seems to work using the default board 0. On a sidenote, I personally do not use this but I have learned trying to help someone else.
Maybe the Robert Overloard wrote it only for board 0? Lol
Thanks again Richard.
@richard r, are you saying it works on any board number or only on board zero
I only tested it on board 0... I will try after dinner on another board connection...
