Openai Dall-E Image icon Openai Dall-E Image — Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands. Try it →
@Dj Or? Sound Servo(Ezb Playback)
I've been testing Rich's led tutorial https://synthiam.com/Community/Tutorials/135/1
I've been able to get it to work on, sound movement, sound servo(PC Mic), sounds servo(PC Speaker) but not able to get it to work with sound servo(EZB Playback). I have also noticed when hitting the? On the sound servo(EZB Playback) goes to the webpage talking about the sound servo(PC Mic). ?
Also when I use the sound servo(EZB Playback) and play something [sayezb(" test test test", 3) i hear this on the ezb speaker but the level on the sound servo(ezb playback) shows 0 never changes.
Well maybe I'm not understanding but I thought the sound servo(ezb playback) is used for the sound coming out of the speaker of the EZB controller to control a servo or in this case the LEDs.
Thanks
It's interesting on the Sound Servo(EZB Playback) it doesn't matter if you have board 0, 1, 2, 3 or 4 selected it still works as long as you are connected to EZB controller board 0. No other controller board 1 thru 4 will work?
So is this a bug or a feature?
@Richard R please verify. Thanks
Just tested this and yes, it looks like it only works on board 0
