Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
Servo Panel For Hitec
hi
wil there be a servo panel availeble to controle  the Hitec HS-805BB and HS-5765MH .  bolt doesn work anymore . i have power , ground averywere . servo's doesn move . they did worked before .
thanks
Persist and auto-load specified global variables between ARC sessions for consistent, personalized robot behavior and quick state restoration.
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
Horizontal Servo by Synthiam
Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert.
When a servo gets very warm, it can be due to several reasons. Here are some common causes and troubleshooting steps:
  1. Overloading: If the servo is trying to move a load that is too heavy or if it is stalled (unable to move), it can draw excessive current, causing it to heat up. Ensure that the servo is not being overloaded.
  2. Voltage Issues: Although you mentioned using a voltage regulator to provide 6V, ensure that the voltage is stable and not fluctuating. Also, verify that the voltage regulator can supply enough current for the servo. The Hitec HS-805BB and HS-5765MH servos can draw significant current, especially under load.
  3. Continuous Operation: If the servo is continuously moving or holding a position under load for an extended period, it can heat up. Ensure that the servo has some rest periods if possible.
  4. Mechanical Binding: Check for any mechanical binding or friction in the servo's movement. Ensure that the servo horn and any connected linkages move freely without resistance.
  5. Incorrect Wiring: Double-check the wiring to ensure that the servo is connected correctly. Incorrect wiring can cause the servo to malfunction and heat up.
  6. Faulty Servo: If the servo has been used extensively or has been subjected to harsh conditions, it might be faulty. In such cases, replacing the servo might be necessary.
  7. Environmental Factors: Ensure that the servo is not operating in an environment that is too hot or has poor ventilation.
Troubleshooting Steps:
  1. Check Load: Ensure that the servo is not trying to move a load that is too heavy. Reduce the load and see if the heating issue persists.
  2. Measure Voltage and Current: Use a multimeter to measure the voltage and current supplied to the servo. Ensure that the voltage is stable at 6V and that the current is within the servo's specifications.
  3. Inspect Wiring: Double-check all connections to ensure that they are secure and correct.
  4. Test Without Load: Disconnect the servo from any mechanical load and test it to see if it still gets warm. This can help identify if the issue is with the load or the servo itself.
  5. Check for Binding: Manually move the servo horn to check for any mechanical binding or resistance.
  6. Replace Servo: If the servo continues to get warm despite all checks, it might be faulty. Consider replacing it with a new one.
Additional Resources:
  • Servo Tutorial: For more detailed information on how servos work and how to troubleshoot them, you can refer to the servo tutorial on Synthiam's website: Servo Tutorial
If you have any specific questions or need further assistance, feel free to ask!
the servo is brand new . no load or any material is connected . no mechanical binding . i notest that the respons of the servo is slow . it takes about 2 seconds before the servo reacts . also ARC crashes when i use these servo's to fast .
You will need to clarify if ARC is crashing or disconnecting because there is no bi-communication between these servos, as they work like all other hobby PWM servos. If there is a crash, a popup with a message will be displayed. If you can provide the crash message, that would be helpful. If the EZB is disconnecting from ARC, that is most likely power-related.
ARC craches it doesn disconnect . the connection stays on but the ezb disconnects . no message is displayed . am using two batteries . 7.4 volts . one for the ezb and one for the voltage regulator . i also notest the regulator gets a little warm .
#7   — Edited
I reviewed the log and ARC is not crashing. It’s disconnecting. This is most likely due to brownout. When the ezb isn’t getting enough power for the servo. The servo is shorting out the ezb or taking too much power and the power supply isn’t enough
here’s the error that you keep getting
Quote:
testRegulator.EZBComm Err: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Your voltage is 7.724868000, which is fine at startup. Ensuring the battery is fine or power supply. I’m guessing the servo is either damaged and that’s why it’s shorting out. If it’s moving slow it could be that reason
is it hard to move by hand? Usually when a servo is on its way out they have a funny smell or they’re hard to move by hand
Hey nomad, synthiam support is correct. There's no way the servo could "Crash arc" because it operates the same way all of your servos do. It's not a "smart servo" that requires any protocol or anything. It simply needs to be connected like you do with all other PWM hobby servos. There is no "two-way communication" that could cause ARC to behave strangely. ARC sends a command and the servo moves.
I would think what is suggested is that the servos are drawing too much current and browning out the ezb, which is causing a disconnect.
The servos could be drawing too much current because they are damaged internally, which I hope is false. But that could be the case with those types of servos. Finding reliable, strong PWM hobby servos is difficult, so we spent hundreds of thousands of dollars on research to make the ez-robot servos.
