hi
wil there be a servo panel availeble to controle the Hitec HS-805BB and HS-5765MH . bolt doesn work anymore . i have power , ground averywere . servo's doesn move . they did worked before .
thanks
Task Script
— Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation.
hi
thanks
hi dj and synthiam support
okay brown out the ezb . it only happens when move the servo fast .
thank you bolt
Yeah, that would make sense. When the servo moves quickly, it draws too much current-the current drops, so the voltage drops. You can try increasing the voltage a little bit. But I think what you need is more current. OR you are trying to control too many servos and drawing too much current.
@dj
for now am using only one servo .no load . maybe i can try to slow down the servo ? or using the big voltage regulator on the chair ?
