Does Shortcut Creator work in ARC?
The Create Shortcut and Copy file path to clipboard are both greyed out and not clickable
Thanks Steve
Slide Script
— Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press.
Thanks Steve
I'm trying to create a auto connect script using the EZ-Load Creater, but as I get to saving the shortcut, the Create shortcut box and the Copy file to clipboard box is greyed out, and won't allow me to select them? I have completed step 1-4 in the EZ-Load Creater correctly.
Any idea why?
I'm using the latest ARC release.
Hey guys - i took a look and ARC indeed has this issue. I fixed it and it will be included in today's release later this evening. Thanks for the heads up
Cheers, thanks DJ :-)
Fixed here: https://synthiam.com/Products/Releases/ARC-Beta-2020-03-19-00-19052
Thanks DJ, I’ll try it out later day.
Of course it works perfectly now ;-)
Thanks DJ
Hey, Im having an issue with the Shortcut Creator as well. I am using latest and greatest ARC version. I have one project that I created the shortcut for already which was done long time ago. Now I want to add 2 more project shortcuts. When I tried to create my second project short, the creator went thru all steps, but in the end never created the shortcut upon my desktop. The original first one I ever did is still there, but no second one, nor could I find it anywhere on the computer. So, can I create only 1 shortcut and no more?? am I missing something???
I tested it, and it works fine. Make sure you follow the instructions, I guess is the advice I can give
