Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
ARC Shortcut Creator
Does Shortcut Creator work in ARC?
The Create Shortcut and Copy file path to clipboard are both greyed out and not clickable
Thanks Steve
Lattepanda by DF Robot
LattePanda with Synthiam ARCx runs headless, loads EZB firmware on the built-in Arduino, and controls robots from any browser
Servos 12
UART 1
ADC 5
Digital 12
I'm trying to create a auto connect script using the EZ-Load Creater, but as I get to saving the shortcut, the Create shortcut box and  the Copy file to clipboard box is greyed out, and won't allow me to select them? I have completed step 1-4 in the EZ-Load Creater correctly.
Any idea why?
I'm using the latest ARC release.
Hey guys - i took a look and ARC indeed has this issue. I fixed it and it will be included in today's release later this evening. Thanks for the heads up:)
Thanks DJ, I’ll try it out later day.
Of course it works perfectly now ;-)
Thanks DJ
Hey, Im having an issue with the Shortcut Creator as well. I am using latest and greatest ARC version. I have one project that I created the shortcut for already which was done long time ago. Now I want to add 2 more project shortcuts.  When I tried to create my second project short, the creator went thru all steps, but in the end never created the shortcut upon my desktop. The original first one I ever did is still there, but no second one, nor could I find it anywhere on the computer.  So, can I create only 1 shortcut and no more?? am I missing something???
I tested it, and it works fine. Make sure you follow the instructions, I guess is the advice I can give:D
