Does Shortcut Creator work in ARC?
The Create Shortcut and Copy file path to clipboard are both greyed out and not clickable
Thanks Steve
Ez430-Chronos Wrist Watch
— Map TI eZ430-Chronos watch accelerometer X/Y tilt to ARC servos for intuitive, Wii-Remote-style control of servo positions.
Thanks Steve
PS, here's the step by step instructions. Just make sure you remember where the shortcut file was selected to be saved. You might have several in a weird folder that you accidentally selected
Hi DJ, and thanks. I did follow the instructions, making sure to use all the default settings as I went thru each step, thats why I am a bit lost, Its not where I thought it should be., even when I did a total search of all drives, nothing showed up. Yes odd. I will keep looking of course, It has been a long time since I've used this feature.
