Sound Script (Ezb) icon Sound Script (Ezb) — Trigger a script when EZB audio plays, exposing live Min, Max and Avg audio-level variables for looped monitoring; stops when audio ends. Try it →
Arc X Migration Compatibility
Will installing ARC X on a computer that already has the ARC application (Autonomous Robot Control) cause any conflicts or problems if both are present on the same PC?
How do I migrate or port my existing ARC application data - projects, Robot Skills, and any custom JavaScript/Python scripts - to ARC X? Is there a recommended migration process?
Will Robot Skills written for ARC be compatible with ARC X, or will they require updates to work in ARC X (for example, changes to skill code, settings, or EZB connections)?
USB
Digital 21
Auto Position by Synthiam Inc.
Animate servo groups with frames and actions for waves, nods, gestures, and other robot motions.
#1   — Edited
You’re right to be cautious here. ARCx is not a newer version of ARC, and ARC is not being replaced by it. ARC and ARCx are separate products with different robot skill frameworks and different project formats, so the answer is mostly:
  • Yes, they can both be installed on the same PC
  • No, they do not share projects or robot skills
  • Most ARC robot skills will need an ARCx-specific version or a rewrite
  • Custom scripts may copy over sometimes, but they are not guaranteed to work unchanged
Read this: https://synthiam.com/Support/using-arcx/arc-vs-arcx
What happens if both are installed on the same PC?
Usually, there’s no inherent conflict just from having both installed. They are different applications with separate project files and separate robot skill systems.
That said:
  • They are not interchangeable
  • They use different product seats/licenses
  • A project opened in one cannot be opened in the other
So the main "problem" isn’t installation conflict - it’s compatibility.
Migration / porting process
There is no direct migration tool that converts an ARC project into ARCx. The practical process is to rebuild the project in ARCx.
  1. Inventory your ARC project
    • List every robot skill in use
    • Note their settings
    • Export or copy any scripts
    • Document EZB connections, COM ports, board indexes, and custom variables
  2. Check ARCx equivalents
    • In ARCx, look for the matching robot skills in the Add robot skill menu
    • Some skills may exist in both products, but they are not the same skill internally
  3. Recreate the project in ARCx
    • Add the ARCx version of each skill
    • Reconfigure settings manually
    • Rebuild any layouts or custom UIs
  4. Port scripts carefully
    • JavaScript and Python scripts may need changes
    • Test each script against ARCx’s API and available commands
    • Do not assume ARC scripts will work unchanged
Robot Skill compatibility
Robot skills written for ARC are not compatible with ARCx in the general sense.
Important distinction
Even when a skill has the same name in both products, it is still often:
  • a different codebase
  • a different configuration format
  • a different command set
  • a different UI/configuration model
So yes, skills may require updates for:
  • skill code
  • settings
  • control commands
  • EZB connection assumptions
  • project structure
What is portable?
DJ’s note is correct: Auto Position and RGB Animator are the only two skills that can be imported from ARC to ARCx.
For scripts:
  • Some JavaScript/Python can be copied
  • But it is never guaranteed
  • You should expect to revise scripts and verify functions one by one
Best practice in ARCx
Instead of trying to "convert" an ARC project, I’d recommend this workflow:
  • Start with a small test project in ARCx
  • Add only one or two skills first
  • Verify your hardware connection and board indexing
  • Port one script at a time
  • Confirm servo, digital, PWM, and UART behavior before moving on
That avoids chasing multiple issues at once.
If you’re evaluating ARCx
If you’re happy with ARC already, there’s no need to move just to move. ARCx is intended for a different use case, and it’s worth adopting only if you need things like:
  • Linux or Raspberry Pi deployment
  • headless operation
  • browser-based multi-user access
  • kiosk/public UI use cases
More detail here:https://synthiam.com/Support/using-arcx/arc-vs-arcx
If you want to port a specific project
I can help you map an ARC project into ARCx step by step. If you share:
  • the list of ARC robot skills you use
  • your JavaScript/Python scripts
  • how your EZB is connected
  • what the robot is supposed to do overall
I can tell you which parts are portable and which parts need a replacement in ARCx.
The bigger question is: what is your end goal with the robot - are you trying to run the same robot on a different computer, move to Linux/Raspberry Pi, or just evaluate ARCx for a new build?
If you want, I can also help you create a migration checklist for your specific project.
I remember @DJ mentioning this. I haven't worked much at all with ARCx but intent to soon. I have a few large Auto Position skills currently in my ARC project. I haven't seen how to port this one allowed skill from ARC to ARCx.(have not really read the guide closely). Could you outline how to do this?
Yes - that’s the correct path. Auto Position is one of the few ARC skills that can be moved into ARCx via export/import, and the workflow is pretty straightforward.
ARC ARCx Auto Position transfer
In ARC
  1. Open your Auto Position skill.
  2. Open the skill’s kebab/hamburger menu in the top-right of the skill window.
  3. Choose Export.
  4. In the export dialog, select the frames/actions you want to include.
  5. Save the exported file.
In ARCx
  1. Add the Auto Position robot skill.
  2. Open its kebab/hamburger menu.
  3. Choose Import.
  4. Select the exported file from ARC.
That’s it for the basic transfer.
A couple of important notes
  • Importing is skill-specific: it won’t move the rest of your ARC project, only the Auto Position content.
  • If you have multiple large Auto Position configs, export/import each one separately.
  • After import, verify:
    • servo ports are mapped correctly
    • any inversion settings are correct
    • frame positions match your robot’s actual hardware
    • action names and repeats behave as expected
For a big robot, I’d suggest:
  1. Export one Auto Position skill at a time from ARC
  2. Import it into ARCx
  3. Test it on the robot before importing the next one
  4. Keep a written list of:
    • servo names
    • EZB index
    • port mappings
    • any limits or offsets
That makes it much easier to spot issues if one imported animation doesn’t behave the same.
If you’re doing this with scripts
If scripts reference Auto Position actions, you’ll likely need to re-check the ControlCommand names in ARCx, because robot skills are not automatically interchangeable between ARC and ARCx. ARCx has its own skill implementation and control commands.
Useful references
If you want, I can also help you build a step-by-step migration checklist for a large Auto Position project, including how to verify servo mappings after import. What’s your larger goal with ARCx - just moving your current robot, or rebuilding it for a new platform?
