I came across Alturn servos. What would be the proper way to power, connect, and control a servo such as this one " https://alturn-usa.com/products/ARS-3216HTG+HV.htm " with the EZB controller?
Thank you.
EZB Connect By Name
— Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC.
Thank you.
Since the servo uses PWM for control, it "may" work directly with the ezb4 (from the servo stats 280 degree / 0.9us ~ 2.1us PWM) ... However having a 280deg rotation angle you might be able to control it much better (greater rotation angle) using an SSC-32 board....
Thank you Richard, I will look at using the ssc-32 with the ezb.
