Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
Since the servo uses PWM for control, it "may" work directly with the ezb4 (from the servo stats 280 degree / 0.9us ~ 2.1us PWM) ... However having a 280deg rotation angle you might be able to control it much better (greater rotation angle) using an SSC-32 board....
Thank you Richard, I will look at using the ssc-32 with the ezb.
