Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Help With Damaged Project File
I worked all day yesterday and til about 3AM in the morning. I was on a roll. I saved my programs to the cloud and then I added personal stuff and saved them to my hard drive. Next I upgraded my builder. Things were working absolutely perfect last night. When I tried this afternoon at 2:00pm to open my file from my Hard disk, it said the file was corrupted or not the right version. Next I tried to open the file I had saved to the cloud and it gave me the same message. I am always updating and have NEVER had this problem before. I tried to install the previous version that I had on my hardrive saved and it told me that I could not downgrade because there was a newer version already on the machine. Then I tried to repair and it did complete. But, I still cannot access the programs I worked so hard to build.
Any suggestions??? Please Help!!!
Thanks in Advance!!!!
Mel
P.S. Sorry I put the title wrong.
Are any of your cloud files in the public area? if so I could try them. My cloud files I created sometime ago seem to work ok
I would go to control panel and uninstall ARC then download and install latest version
I did that. But it is telling me it was the wrong version. But I will try it again.
Maybe the file was too big. It was 324mb. It was working so good when I went to sleep.
You can post your saved EZB file here and we can try it. Use the "attach File" option on the right of the edit box for your message. select the file and press UPLOAD.
It wouldn't let me upload it. But it is on the cloud. The name is: useful commands. If you can get this working, I would like to try the one on my HD. But, that one is 317mb. It won't allow me to upload.
I have Uninstalled all previous versions of EZB and installed them back one at a time. But, somehow the file got corrupted, I guess. I was able to load and run all of the previous files that I did that day. Just this one file. Of course , it was the biggest and nicest yet
The Cloud file useful commands is zero length and won't load so yes corrupted
And, on my end, it says that it is 317mb. But, it wouldn't load either. Something went wrong. I will just erase it and start over. But it was sooo cool. It was doing all kinds of stuff.
