Sighthound Cloud API icon Sighthound Cloud API — Cloud-based detection of people and faces in robot camera video; returns locations, gender, age, pose, emotion, plus 68-point facial landmarks. Try it →
Help With Damaged Project File
I worked all day yesterday and til about 3AM in the morning. I was on a roll. I saved my programs to the cloud and then I added personal stuff and saved them to my hard drive. Next I upgraded my builder. Things were working absolutely perfect last night. When I tried this afternoon at 2:00pm to open my file from my Hard disk, it said the file was corrupted or not the right version. Next I tried to open the file I had saved to the cloud and it gave me the same message. I am always updating and have NEVER had this problem before. I tried to install the previous version that I had on my hardrive saved and it told me that I could not downgrade because there was a newer version already on the machine. Then I tried to repair and it did complete. But, I still cannot access the programs I worked so hard to build.
Any suggestions??? Please Help!!!
Thanks in Advance!!!!
Mel
P.S. Sorry I put the title wrong.
#17
I will look and see. In sound board, it only takes wav files , doesn't it? MP3 would be smaller. But, I don't know all of the technicalities about that.
238K for all of them
NOTE* I am sorry, 238 MEG not K.
Ok, the largest is 369k and the smallest is 16K and the rest are everything inbetween.
#18
I did a Windows Upgrade to get the latest everything. I did a SFC SCANNOW to check the system files. I did a Virus Scan. Everything came out great.
Next, I did a series of Tests:
Test1 = 1 small soundbyte: =normal save and retrieve. Test2= 3 small soundbytes: normal save and retrieve. TEST3= 3 small soundbytes and 1 large complete song . = Saved, but could not reload. Test4= 3 small soundbytes and 1 complete song= 24Megs=Saved and loaded fine.
I believe the size of the files matter. I believe the song was around 210k.
Maybe this data will help you determind what we can do.
thanks,
Mel
#19
Thanks for the test results.
I moved your information from the other thread you created into this one. Only need one thread for this discussion.
#20
I have done some more tests. I added upto 24 files to put in the sound board. When I got to 25, it would not let me open the file. Then I took about five small files out and added large files upto 24 only.
Results, I have loaded upto 28 files, so there is no 24 limit.
But, you are limited on your megs. I could not manage over 289.6 megs with upto 28 files or a single file over that amount.
So , you can Increase your Megs or You can just tell us don't go OVER 289 Megs. Now it is possible that there is a 300gig limit,but I had no way to test that.
hope that this helped.
Mel
#21
That was all of the tests that I ran.
#22
Hehe, i don't think anyone has used that many sound files before:) Or at least in that file size.
Regarding the 289 MB limit, are you referring to the saving to the cloud, or to the HD?
#23
Saving to the hard drive or the cloud.
Also,
I needed to play 40 soundbytes. Then I found I could not do them because you can have only one soundboard per project. When I reach the limit, it won't let me go further. I am going to have to shave my program back a little. I wanted to do major stuff with it. I will be happy when Synthia comes out. I am making a sort of sudo-chat algorythm. That is why I needed 40 soundbytes. When I am talking to the robot and I ask if she has ever heard of Lost in Space, she will play "Danger!Danger! Will Robinson!" and so forth and so on. I have about 40 soundbytes and they are neat.
Also, I have a lot of stuff she can simply Say. There are about 40 more. Then it starts to look like A.I. a little bit.
#24
OK, I kinda sorted out what was most important and using the guidelines and limits made a mainbase chat program. I got in about 95% of my Must haves. It came out good. I tried to upload it to the cloud,but it would not let me. But, at least I can operate it.
Now, my next big step is to add it to the main controller program or add the other functions to this main unit. I know how to do them manually, but it would be nice if I could just add or call those programs like weather,news,sports,jokes. They are all working seperately. In my minds eye, I will totally communicate with the robot through voice and call all separate programs that way. At the end of one, I could call another sort of like a subroutine. But, you will be nice if you let me know if I can do that or not.
Any thoughts, let me know. and have fun at RoboGrl's party.
Bye for now!!
Mel
