Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
Help With Damaged Project File
I worked all day yesterday and til about 3AM in the morning. I was on a roll. I saved my programs to the cloud and then I added personal stuff and saved them to my hard drive. Next I upgraded my builder. Things were working absolutely perfect last night. When I tried this afternoon at 2:00pm to open my file from my Hard disk, it said the file was corrupted or not the right version. Next I tried to open the file I had saved to the cloud and it gave me the same message. I am always updating and have NEVER had this problem before. I tried to install the previous version that I had on my hardrive saved and it told me that I could not downgrade because there was a newer version already on the machine. Then I tried to repair and it did complete. But, I still cannot access the programs I worked so hard to build.
Any suggestions??? Please Help!!!
Thanks in Advance!!!!
Mel
P.S. Sorry I put the title wrong.
Thats a shame it had already gone when I looked again. At least you seem to be up and working again :)
I will reprogram it over a period of the next few days and post it back.
Mel
So sorry Mel. What an absolute bummer!! I know how dishearting it can be. I lost one of my projects in the past. Ever since I always save my projects to a flash drive and to a external hard drive. So far, so good. Hang inb there my friend.
I had it saved in lots of places. But, NONE of them would reload.
Ok, I did a little experiment. I put all of the items I wanted to do in the file and saved it. IT became corrupt upon reload.
I did another program and had only 3 of the items. I saved it and reloaded it and it worked fine. so, there MUST be a limitation that I am violatiing. If someone knows , please let me know.
Thanks for your support.
I tried 3 files, worked great. Next I tried 12 files and I got an error that there was a problem with the saving of the xml file. Only 12 files!! I will continue testing. With 12, I was able to save to the hard drive, but not the cloud.
It looks like it's a soundboard issue hmmm... i haven't experienced this before. i'll poke around and look
*note: i deleted your other threads you started on this topic. one thread makes it a lot easier.
#16
how big are your audio files that you are adding? if the saved file is 365mb, are the audio files that large also?
