does anyone has done the offset from jd? and second howmany degrees is jd neck ?
— Edited
9 Participants
TCP Clients
— Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections.
I've done some of the lessons two or three times now. There is no limit on how many times or how often you can do the lessons.
The more you do them the better you will understand them.
Do them now, without carrying out the actual practical side of things. Understand what is required, what you will need and what you will need to do. Then, when you are confident that you know what you are doing follow the same lessons and do the practical part at the same time.
I think I read the calibration lessons twice before even attempting it. It was only yesterday that I first tried calibrating the correct way (before then I was fine tuning which is missing the most important steps).
If you go through them now you can see in advance any parts which you may not understand and be ready to ask questions when you go through it with @d.cochran.
rr&rich
i just try it but i lost the webpage.cant find it back
confused You lost what webpage? The lessons? Are you saying you lost the whole Learn section?
@Nomad... Do you not understand the biggest reason you can't get JD working is because you refuse to do the tutorials? You know, d.cochran may not always be able to help you. Eventually you are going to have to do this stuff by yourself... Also eventually everyone else may stop helping you because you won't help yourself....
in the tutorial say pic4 connect to web 192.168.1.1,it stop connecting. i dont no why.aslong i dont understand the tutorial ,i can set it as complete. and yes rr there will be a time no one wil help.i hope then i can do it myself. surtenly its not cause am refusing.but dont get you hopes up. i know myself.it will be a miracle if i can understand it.
Oh Lord help @Nomad... you had all your connection problems fixed last night with d.cochran, remember? Why can't you connect now? We're all going in circles here Patrick....
And that's why you should have gone through the lesson sooner. We can help you on any step you are stuck with. Until now we did not know step 4 was a problem for you.
Step 4 actually says to connect to the WiFi connection transmitted by the EZ-B.
Which part of this are you struggling with? Does the EZ-B not show up? Can you connect to it or does it give an error on connection? Have you changed any settings on the EZ-B? If so, have you reset the EZ-B? (I suggest you do that lesson first since you are not yet capable of following the lever servo calibration lesson).
You understanding it is not difficult. But we cannot read your mind. You have to tell us what steps you are stuck on and why. Be precise and be as clear as you can be.
@Nomad... Post #63 d.cochran said...
