Servo Sketch 3D icon Servo Sketch 3D — Real-time 3D servo visualization with motion trails, interactive camera controls and clear trail for ARC debugging and analysis. Try it →
#89
@Rich Look at his post #69... Nomad claims he was already doing the calibration... Question is if he still can't connect how could he be doing the calibration?....
#90
Thanks (recently I've not been able to catch up with all posts so do miss a few and do forget a few things I have read).
If your EZ-B is in Client Mode (and I suspect they are) the lesson cannot be followed exactly. The lesson is for the EZ-B in AP mode. The connection method for each differs a lot.
Nomad, can you confirm which mode your EZ-B is in, AP mode or Client Mode? If it is in Client Mode please let me know the IP address assigned to the EZ-B
We need this information in order to help you. Without it we cannot advise on how to reach Step 7.
@Richard, I know, I know... One final attempt and hopefully this time he follows instruction to the letter.
rich yes that one.i dont know why it doesn connect no more. rr i did try thismorning the calibration,but had to charge the batt,after that i couldn connect.
#92
Nomad, you did not answer my questions clearly or precisely. Nobody is able to help you until you answer the simple questions I have just asked.
#93
@Nomad... Did you connect to the ezb4 before you tried 192.168.1.1? Look at Rich's post #88... You have to connect to the ezb4 first (solid blue LED) before you go to 192.168.1.1
got blue solid led.but web page not schowing on pc.accses point is flikkering
#95
Please answer the questions I have asked. Depending on the answer to the question I have now had to ask three times will make a difference to what Richard is explaining.
rich&rr
let us stop and let david handle this.i dont want to risk that david has to do all over.
thank you for trying.
