Servo Sketch 3D icon Servo Sketch 3D — Real-time 3D servo visualization with motion trails, interactive camera controls and clear trail for ARC debugging and analysis. Try it →
#97
they are in client mode.
his ip and port are 192.168.0.128:23 I believe. working off of memory here.
#98
Sorry that I haven't been following along. Had the server at the school decide to go haywire with its NIC, a server at work decide to shutdown and I am trying to figure out if someone did that or if it "just happened" and then a request for some data from our primary investor.
Hope this helps. I will be away most of the day, but will check back with my phone.
#99
Thanks @d.cochran.
@Nomad, if you want an enjoyable experience you will need to let people try and help you when you ask for help and you will need to work with them when they ask you questions.
You will not need to change anything that David has done to calibrate your servos or follow the lessons. It's a minor change to the lesson so that you connect in Client Mode rather than AP mode which doesn't change any network settings on either the Access Point or on the EZ-B.
This is post #100 (unless someone else replies) of one of three topics covering your issues. You have had numerous people attempting to help you, taking up their time. I do not understand why you are refusing to cooperate by answering two simple questions that I needed to ask three times and now refusing to accept any help from anyone but David.
I could have had alternate steps to the Lever servo Calibration lesson written up, with images in no time at all and you could move on to step 7 of the lesson with no trouble.
i dont think the problem can be solved here. it s the new accses point is blinking.david is the one who knows it. i maneged the find the blue led solid.but then all stops. on android.i check nm 7.
i cant see pic7 cause connection problem whit the new accses point. all off ez goes thru that point.
#102
I do not recommend the access point nomad got. I have the Same one and it constantly fails. Reset annually.
#103
I give up. It's as if you didn't even read my post! The access point remains unaffected. The EZ-B network settings remain unaffected. I would have provided you with bespoke instructions for your situation so that you could get past step 4 and on to step 7 of the lesson.
However, in order to do that I needed to know some details which I asked for three times and still you didn't answer the questions (David did).
It's taken over 100 posts, 3 topics, a few days and a bunch of people to get this far and you still are at step 4 of the lesson and failing to give the information required when asked for it, failing to read posts (and if you cannot understand what is being said, failing to ask questions!), it's a huge waste of resources and I cannot waste my time. I'm happy to help anyone who needs it but they must cooperate, must read, must question when they don't understand and most of all must provide the required information.
Good luck with the calibration and I hope you solve your issues soon so you can enjoy JD.
#104
I am done too... I will continue to follow this thread because lets face it, it's a train wreck and hard to look away...
@Nomad.... I do hope you get this sorted out... Good luck
