Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Spain
large file bug
Hello, I have had problems with ez-saving project builder, I have installed the latest versions of ARC and filmware. After adding the function "recorder" menu scripting and recording a sequence of movements of servos, saving the project went well, but I went to open it again this message
I have also noticed on other occasions it was not possible to record on a project a sequence of movements of the "recorder" of ARC , I mean that when I opened the project and the recorder did not appear in it. I tried opening the project in my pc and my pc laptop with the same result, both windows 7, I attach the project file that has this error: cabeza.EZB Appreciate any help, thanks stress
I just tried saving a project recording Bob moving a few meters as part of my next Project.
I get exactly the same error message as you guys.
DJ please look into this code error on this and get back to us. :) mad
Large recordings run out of memory in saved files. There is an item list to use an alternative storage method.
These are not large files - Are saying is that we cannot save recordings ? sick If there is an alternative - SHOW US HOW IT WORKS..please confused
Recordings currently create large files. There is a bug with large files in recordings. There is an item on my to-do list for this. However, repeated questions on the same subject thread occupy my time and prevent me from working:)
If you could please refrain from repeating the same question, items will be addressed in their order.:)
Dear DJ, the wonderful things that you have enabled us to do with our robots (talk, see, read, tweet, move etc) are nothing else but miraculous! I deeply appreciate your efforts to fix the bug and have faith that not only you will but also CAN do it in way that will exceed all our expectations as you always do.
Has anyone got some tissues..at least now we know it's a bug ! I will stop trying different things from my end ;) ;) ;)
#16
Use the latest ARC and resave your files to the cloud. The large file up to 32mb has been resolved.
Old broken files will not work
