Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
Spain
large file bug
Hello, I have had problems with ez-saving project builder, I have installed the latest versions of ARC and filmware. After adding the function "recorder" menu scripting and recording a sequence of movements of servos, saving the project went well, but I went to open it again this message
I have also noticed on other occasions it was not possible to record on a project a sequence of movements of the "recorder" of ARC , I mean that when I opened the project and the recorder did not appear in it. I tried opening the project in my pc and my pc laptop with the same result, both windows 7, I attach the project file that has this error: cabeza.EZB Appreciate any help, thanks stress
Spain
#17
Thanks Dj for its efficiency and speed, I'll prove it tomorrow.:P :)
#18
Thanks DJ for squashing this bug so fast! I was able to test it last night and was fascinated to read "saved" on the screen! I have also noticed that as you mentioned, older project files build with the previous version of ARC will not save. This gives me an opportunity to start afresh. I did observed though that it will not save recordings of the Movement Panel even with a new file. I am certain that you, more than anyone else, are aware of this limitation and will address it in due time. As besides, like any great inventor, you keep perfecting your design.;)
#20
I'm using the Hbridge 4 wires movement panel.
#21
That should record also. I'll take a look but it should be fine hmmmm
Spain
#23
Unfortunately I do not work, today I updated ARC and filmware and have proven to records 2 seconds of time and the error message is this:
The message appears when I try to save the file: Error generating the XML document
#24
Do you have any specific language characters in the project? We work with the english language, so perhaps there are issues with different languages within the project.
