Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Spain
large file bug
Hello, I have had problems with ez-saving project builder, I have installed the latest versions of ARC and filmware. After adding the function "recorder" menu scripting and recording a sequence of movements of servos, saving the project went well, but I went to open it again this message
I have also noticed on other occasions it was not possible to record on a project a sequence of movements of the "recorder" of ARC , I mean that when I opened the project and the recorder did not appear in it. I tried opening the project in my pc and my pc laptop with the same result, both windows 7, I attach the project file that has this error: cabeza.EZB Appreciate any help, thanks stress
#25
@R2D2: Did you try saving a brand new project made with the latest version of ARC? I have noticed that if the project is not brand new it will not save it.
#26
@R2D2: How many servos were involved in the recording? Last night I also realized that it will only save if no more than one servo is involved.
Spain
#27
Dj: the file does not have language specific characters, I have proven with names as simple as as a.ezb or rb1.ezb. Nicolson: I created a new file with the latest version of ARC, a simple file with only one panel of the recorder servo horizontal and even the recording of only 2 seconds to avoid a possible saturation of memory, but I been not successful. I would like to work, but I have no hurry, my projects take a great time to complete and is not an urgent issue, but I like to be taken into account in future find a solution that Dj without a doubt. The next test will be updated ARC on my other computer and try again, I will keep you informed, thanks.
DJ: I fully understand your lack of time, and I deeply appreciate your dedication, I am sure you have a thousand things on your list, so do not be overwhelmed with this issue, Greetings.;)
Agree R2D2. I was just pooy because I wanted to use recorder to get Bob to follow his tracks to the kitchen and back but it's not important. I now realize that's way to much memory. My expectations are extreme and I'm sorry about that.
Take a break DJ, there is no way we expect you to cover all this stuff. :) :) :)
Spain
#29
Already checked with my laptop and the fault is the same, it is not my machine, it's a shame because the recorder works great as long as you do not save the project. It would be a silly solution or rare a copy and paste of the positions and time recorder that records and paste them into a script and then run would require a conversion of the lines of position on the recorder to the EZ-Script commands? I hope that the translation is understandable.:)
#30
Hello!
I have the same issue with 'XML doc' error, when trying to save a file, after recording a mouse movement.
I read the entire thread, but since not very technical, maybe missed the solution for the problem.
What should i do?
Thanks, Roi.
